Go Back   Ford Expedition Forum > Ford Expedition Forum > Electrical
Register to remove these ads.
Electrical
Dash light problems
This is a discussion on Dash light problems within the Electrical forums, part of the Ford Expedition Forum category!
Hey I am a new owner of a 1997 Eddie Bauer Expedition. It has 183,000 miles on the 5.4L. It ...
Reply
Old 07-28-2010, 09:20 PM   #1 (permalink)
Registered User
Default Dash light problems
Hey I am a new owner of a 1997 Eddie Bauer Expedition. It has 183,000 miles on the 5.4L. It has a couple issues that I need to figure out. I thought that this would be the best place to ask first.
1. Neither the dash lights or the illumination for the climate control light up. The overhead console does light up and work with the dimmer switch. Everything on the dash works just no illumination. Also the autolamp feature does not work either. Checked all the fuses and they are all good. Not sure where to start checking next.
2. When the truck is switched into AWD the light just blinks. Seems to go into 4x4 high/low just fine. Any thoughts?
I now my way around a multi-meter. So any test I need to perform shouldn't e a problem. Thanks in advance for any help.
Speedaddict is offline   Reply With Quote
Old 07-28-2010, 09:49 PM   #2 (permalink)
ELVATO's Avatar
Super Mod
Default
Check fuse 2 for instrument cluster, and fuse 4 for autolamps. This is for the inside fuses, under steering wheel. Also, fuse 18 in the same location.
Another EDIT: ....and fuse 29. Actually this one might be it, since it shares both items. Same location.
__________________
I'm not responsible if you break something :)
ELVATO is offline   Reply With Quote
Old 07-28-2010, 09:53 PM   #3 (permalink)
Registered User
Default
I checked all the fuses and they are good.
Old 07-28-2010, 10:09 PM   #4 (permalink)
ELVATO's Avatar
Super Mod
Default
With the multimeter, check voltage between the back of the fuses (you know how fuses have those 2 little exposed squares?) while they are pluged in and ground.
I'm guessing these fuses are not hot all the time, so when checking the instrument cluster ones (2, 18, and 29) have the headlight switch in parking or headlight position. For the autolamp fuse 4, turn the switch to autolamp mode, though just make sure it's dark enough where they would normally turn on.
This is to see if you are getting voltage here. If you are, then should be in the wiring after the fuse box. If not, then it might be in the wiring leading to the fuse box. Not sure if that made sense...
__________________
Old 07-28-2010, 10:18 PM   #5 (permalink)
Registered User
Default
Are the fuse in the cabin gonna be the sub fuse? Meaning that the fuse will be after the switch?
Old 07-28-2010, 10:28 PM   #6 (permalink)
ELVATO's Avatar
Super Mod
Default
Not sure, don't have the wiring diagram for a 97. I think pre switch.
__________________
Old 02-08-2011, 02:10 AM   #7 (permalink)
Default
If you figure or figured it out, can you tell me what you did to fix the no dash light problem and climate control lights? Thanks
strokin393 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
