Go Back   Ford Expedition Forum > Ford Expedition Forum > Electrical
Register to remove these ads.
Electrical
Fuel Pump Driver Module
This is a discussion on Fuel Pump Driver Module within the Electrical forums, part of the Ford Expedition Forum category!
This is my 1st post in the forum, but I hope it helps others that have fuel pump problems... We ...
Reply
Old 01-18-2010, 02:12 PM   #1 (permalink)
Registered User
Default Fuel Pump Driver Module
We have a 2005 Expedition and the fuel pump died. Tried to order a new pump only to find they are on national backorder until mid-February. I found a used pump and had that installed. The truck at least started and ran, but still stuttered and missed. Turns out, there is a fuel pump driver module that is basically the brains for the fuel pump. I never heard of this before, but at any rate, here is where lies the problem:
The FPDM sits on the crossmember above the spare tire. Road grim, dirt, salt, etc collect on top of the crossmember and basically rot the FPDM. Take a look at the pic of the FPDM that we removed. The back of the FPDM is supposed to be solid!!!
dwhst9 is offline   Reply With Quote
Old 01-18-2010, 08:40 PM   #2 (permalink)
Stoned06's Avatar
Default
Are you sure someone didn't cut a hole in that?!!!!! Damn...definately not the best place to put something that can't hold up to the road grime. Thanks for the heads up. I'll have to take a look at my '06 to make sure it doesn't look like that.
Stoned06 is offline   Reply With Quote
Old 01-18-2010, 11:28 PM   #3 (permalink)
Registered User
Default
Yeah, not the best design and/or location. Apparently aluminum can corrode over time when in contact with steel. I did not know that.
Old 02-18-2010, 02:19 AM   #4 (permalink)
Registered User
Unhappy 1998 EB no Start
Thanks for the post. Do you know if this would apply to the previous generation of Expy's? (1997-2002) Mine won't start unless I add gasoline through the intake. Thanks.
-Gordon
gfwelkner is offline   Reply With Quote
Old 02-18-2010, 09:09 AM   #5 (permalink)
Default
I just took a quick look underneath my 97 (no spare tire at the moment) and there's no module on those crossmembers. There isn't even any space between the body and the crossmember for anything...!
chrmar is offline   Reply With Quote
Old 04-28-2011, 01:07 PM   #6 (permalink)
Registered User
Default Fuel Pump issues
My 2006 Expedition has been missing / stuttering severly. I took it in for service & they replaced the fuel pump. It's one week later & it's still doing the same thing. Now they say it's the fuel pump driver that is all corroded so they ordered the part. Did I really need the new fuel pump or was that in error?
bareinke is offline   Reply With Quote
Old 02-14-2014, 01:52 PM   #7 (permalink)
Default
I know this is an old post, but I found it while sitting at a repair shop in the middle of a 500-mile trip. I was travelling south in my 06 EB when it sputtered and died at 65 mph. I was stranded on the side of the road waiting for a tow. I checked my obd tool with torque pro and found that the fuel rails had lost pressure, and the computer was getting no signal from the fuel pump. A Google search gave info about this fuel driver being a common fault (http://m.ford-trucks.com/forums/show...339&styleid=20). I gave this info to the repairman who ordered and replaced the part in about three hours from the time that I had broken down.
Sent from my SCH-I535 using Tapatalk
__________________
2010 Eddie Bauer with 63,000 miles
EightIsEnough is offline   Reply With Quote
Old 02-14-2014, 03:16 PM   #8 (permalink)
bedrck46
Guest
Posts: n/a
Default
There have been a few posts recently about this issue
Old 02-14-2014, 04:01 PM   #9 (permalink)
Default
I am on my way again, but my obd does not recognize the new part, and now I get no info from the fuel system. Any wisdom on this issue?
__________________
Old 10-10-2014, 11:19 AM   #10 (permalink)
06king's Avatar
Registered User
Default
It's hard to tell. My 2006 expedition just died and it would not fire up again even though the engine was cranking really well. Mine was a corroded fuel module. It also had a hole in it.
It is worthwhile to check yours out before you're stuck in the middle of the road like I was & have to pay a toll truck and a mechanic to fix it.
It is visible from the rear driver side wheel well... bolted on the inside of the crossmember.
__________________
Now every time I drive, I go on an Expedition!
06 Ford Expedition King Ranch
07 Ford Focus ST
93 Ford Mustang 5.0 LX
68 Ford Mustang Convt 289
06king is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
