1999 door panel removal
napew2009
saskatoon, sk
i recently tried to remove my rear door panels to try to get to door speakers but had a hard time. does anyone have instructions?
SWADE23
QUEENS
I have a 2000 expy and i believe its the same....
The anchors holding the panel on are not the old school plastic pieces that just go in a hole. They are hooks, like an upside down u that go into the door. So when lifting up the panel you have to push up rather than pull towards you.
This is after u remove the screws at the bottom and i believe one by the lever to open the door.
Hope this helps
jkxr4
