Go Back   Ford Expedition Forum > Ford Expedition Forum > How To Section
Sponsored Ads
Register to remove these ads.
How To Section
How To Change Rear Diff Fluid
This is a discussion on How To Change Rear Diff Fluid within the How To Section forums, part of the Ford Expedition Forum category!
Register to remove these ads. It's free! This is a quick how-to for changing your own rear differential oil. this ...
Reply
Old 07-20-2010, 07:41 PM   #1 (permalink)
Default How To Change Rear Diff Fluid
This is a quick how-to for changing your own rear differential oil. this will save you about $40 or so from taking it to a shop.
1)loosen bolts (dont remove) all around diff cover and allow fluid to drain.
2)after done draining, remove diff cover and set off to side.
3)inspect gears for chipped teeth and look in carriage for debris. clean anything out that doesnt belong.
4)replace new gasket or use RTV (black) and put cover back on.
NOTE: if you are using RTV to create a gasket then wait 1hr after putting cover on to let dry.
5)find fill plug and open (should just require 3/8 ratchet, no socket needed, and maybe 3" extension).
6)Fill using owner's manual preferred oil. Trust me, its in there.
FOR 01 EXPY WITH 9.75 REAR....75W140 FULL SYNTHETIC WITH OIL FRICTION MODIFIER...JUST OVER 3QTS.
And there you have it. It just cost you $75 and about 1hr (drain time, wait time on RTV, and fill time) to do the same job that most places charge $110+tax.
I will have some pics to follow.
__________________
01 EB. 4" Rancho Lift. 35" Nitto AT on 18x9 KMC. Warn hidden winch mount with XRC8000 winch.
nvycrmn is offline   Reply With Quote
Old 07-20-2010, 09:30 PM   #2 (permalink)
walnuts4x4's Avatar
Default
you can also spray out the housing and gears with brake clean after the oil drains to clean it out better for a better visual for everything inside.... but good details on doing it.... wanna do mine LOL... wait were is DGray69 he can do it...:D
__________________
6" Fabtech + 3" PA Body Lift + 2" Keys/Spacers = 37 x13.5 ProComp Xtreme ATs on 16 x 10 DC-2s
Rear Cat Delete, True Duals, Flowmaster 40s, Edge CS lvl 2, K&N FIPK, Throttle Body Spacer
walnuts4x4 is offline   Reply With Quote
Old 07-20-2010, 10:00 PM   #3 (permalink)
Default
i was gonna say, where is your mechanic? hahahah
__________________
Old 07-20-2010, 11:57 PM   #4 (permalink)
Default
just in case any of you were wondering what your limited slip rear end looks like...
[IMG][/IMG][IMG][/IMG][IMG][/IMG]
and this is what the fluid is NOT supposed to look like. This is what it looks like when you have water in there...not good.
[IMG][/IMG]
__________________
Old 07-22-2010, 02:34 AM   #5 (permalink)
panda24619's Avatar
Default
what brand are you using? my dad said he would pay for the oil and gasket. and it is about $75 for everything. we can do that next weekend if you want while we do your short shaft.
__________________
1998 XLT 5.4 4x4 - K&N drop in - 3" Bullet Exhaust - Spectre CAI - 2" Torsion crank - 5x7 Kenwoods - 35 watt 3000k KCs behind grill - 265 75 16 Falkens - Black painted stock 16s - Truck Horn - Edge CS programmer - 4 35 watt 5000k KCs on rack - 2100 watt amp - Kicker CVR in custom made box - Old School Realistic CB Radio - Ebay Pa Horn - More to take off...
http://www.lalalalalalalalalalalalalalalalalala.com/
panda24619 is offline   Reply With Quote
Old 07-22-2010, 07:38 AM   #6 (permalink)
Registered User
Default
nice write-up with pics
__________________
1999 EB 4x4
Customized dents & scratches:D
drtj is offline   Reply With Quote
Old 07-22-2010, 03:33 PM   #7 (permalink)
Default
thanks man. just thought i would let everyone know how easy it was.
panda, i used valvoline from napa. it was $14 a bottle (buy 4 of them) and i only bought one bottle of 4oz modifier, but buy the 7oz instead. royal purple was super expensive. i bought the valvoline cuz it said compatible with ford...it shouldnt really matter what brand, as long as you buy the recommended weight. it should be on something like page 252 in your book. just look up fluids and it will tell you the page to find the levels and types. i believe most of the expys take the 75w140 FULLY SYNTHETIC.
__________________
Old 07-22-2010, 07:12 PM   #8 (permalink)
panda24619's Avatar
Default
that what mine takes. i just didnt know what brand you used. a lot of options out there. ill see what oreileys recommends.
__________________
Old 07-22-2010, 09:33 PM   #9 (permalink)
Default
i called kragen (oreilly's) and they said they had some royal purple. its $17 a bottle. you can do this as cheap or as expensive as you want. but i think you are just paying for the name in my opinion.
__________________
Old 07-23-2010, 08:20 PM   #10 (permalink)
Default
you had that wide open and did not put locker in.mmmmm great oppertunity to throw in that detroit, or arb locker. man thats rough. pull it apart again and at least weld that puppy. lmao
__________________
like off roading in a bus, official member of LIFTED EXPYclub
teamxtremeoffroad.com
http://oswegocountyoffroad.hyperboards.com/index
dgray69 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
