Go Back   Ford Expedition Forum > Ford Expedition Forum > How To Section
Sponsored Ads
Register to remove these ads.
How To Section
How to remove C, D, and rear quarter panel trims
This is a discussion on How to remove C, D, and rear quarter panel trims within the How To Section forums, part of the Ford Expedition Forum category!
Register to remove these ads. It's free! This was taken from this thread. I'm just copying the directions to removing ...
Reply
Old 12-29-2008, 03:42 PM   #1 (permalink)
ELVATO's Avatar
Super Mod
Default How to remove C, D, and rear quarter panel trims
This was taken from this thread. I'm just copying the directions to removing the C pillar, D pillar, and rear quarter panel trims.
Here are the directions to taking off the rear quarter panel. Should take a couple hours to do the whole thing.
First, you have to remove the C pillar. This is done:
1. Set the seat belt slider thing to it's lower setting.
2. Expose the nut that holds the seat belt, and take it off. I used an 18 mm socket, though I think it's really a 17 mm nut. When putting it back on, this nut requires 30 ft-lbs of torque. Set the belt aside.
3. Above this, there should be a piece of trim in a circle shape. Pop it off, and loosen the bolt. I used a 5/16 socket. It's retained in there, so it won't come out, but you'll know when it's loosened all the way.
4. Carefully pop the whole trim piece off.
Next, you have to take out the D pillar trim piece. This is done:
1. Expose the bolt that holds/guides the top of the 3rd row seat belt. Again, it's behind the little cover that pops off. Use a T50 star bit to take it off. It comes off all the way. When torquing back in, use 30 ft-lbs of torque.
2. Remove the headliner trim piece that is between the rear light and tail gate, or between both D pillars. Just carefully pull down.
3. Carefully remove the D pillar, first by pulling down on the horizontal part, then forward on the vertical part.
Now we get to the good part.
:) This is how you remove the rear quarter trim piece. I did all this with the 3rd row folded down:
1. Remove the rear trim piece that's between the carpet area and the bumper (aka the long trim piece that mostly surrounds the rear latch). Carefully pull up on it.
2. Open the jack access carpeted thing, and remove it. Basically, pull it up about 30 degrees, and pull towards you.
3. Take out the jack, and whatever else you have in the carpet.
4. Remove the 3 black plastic pins that are towards the front of the black carpet thing (assuming you're in the back, facing front towards the motor). Pull them out with pliers. If you want, you can also take out the 2 black screws that hold the latch for the jack assemble access. I used a 5/16 socket.
5. Take out the 2 black screws that hold the black plastic and split carpet (the 2 "flaps" that sit sit behind the 3 row seats) combo. I used a 5/16 socket. Carefully pull up, as it is also retained by clips.
6. Take out the 3rd row seat belt anchor on the floor. It come out with a T50 star bit. When torquing back, use 30 ft-lbs of torque. It'll be attached to a black metal piece that goes into the floor. I guess it's there to stop it from rotating.
7. Remove the pin from this:
I didn't have to since it was broken on mine.
8. Go back to the second row passenger side door, and remove the lower second row seat belt anchor. Lift up the flexible plastic piece and the bolt should be right behind it. I think it uses the same T50 star bolt as the rest, but I can't remember. When torquing it back, use 30 ft-lbs of torque. It makes it easier if you fold the second row seat forward, as if you are exiting the third row seat.
9. Remove scuff plate to the second row door by pulling up. It'll be attached to the black weather stripping so don't be surprised it if also comes up.
10. The final moment is here. Carefully pull on the rear quarter panel towards the center of the vehicle. Disconnect the rear power point plug. It should look like the first picture I posted in the beginning.
__________________
I'm not responsible if you break something :)
ELVATO is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
