Go Back   Ford Expedition Forum > Ford Expedition Forum > How To Section
Sponsored Ads
Register to remove these ads.
How To Section
Oil filter Mounting Gasket.
This is a discussion on Oil filter Mounting Gasket. within the How To Section forums, part of the Ford Expedition Forum category!
Register to remove these ads. It's free! I noticed a small leak near the oil filter and was told it ...
Reply
Old 09-20-2009, 04:19 PM   #1 (permalink)
Registered User
Default Oil filter Mounting Gasket.
I noticed a small leak near the oil filter and was told it the Oil Filter Mounting Gasket. The part is readily available, but has anyone ever done this job? I was told I had to drain the oil and the coolant. No biggie. I was wondering if there were any little surprises in store for me once I get under the truck?
Any assistance is greatly appreciated.
Thanks......Paul Schabner
Paul S is offline   Reply With Quote
Old 09-28-2009, 10:07 AM   #2 (permalink)
ELVATO's Avatar
Super Mod
Default
What year is your Expy, again?
__________________
I'm not responsible if you break something :)
ELVATO is offline   Reply With Quote
Old 09-28-2009, 10:13 AM   #3 (permalink)
Registered User
Default
My Expy is a 2000 xlt, with the 4.6 engine.
Old 09-30-2009, 09:08 AM   #4 (permalink)
ELVATO's Avatar
Super Mod
Default
Sorry for the delay. I'll check my manual when I get home.
__________________
Old 10-14-2009, 03:32 PM   #5 (permalink)
Default
might be a little late, but dont you just need to pop off the filter and put in a new one? (ensuring the old filter gasket is off as well)
if I didnt understand what you mean (and to the uninformed as well), pls update your thread
__________________
00 XLT 5.4
z168 is offline   Reply With Quote
Old 10-14-2009, 05:01 PM   #6 (permalink)
tonydiv's Avatar
technical advisor
Default
Did they mean the oil filter mount gasket? Are they are saying that it's not the filter leaking but the mount itself? I can't remember if the 4.6 has the filter mounted remotely like the 5.4 does.
__________________
1998 XLT 4x4 5.4, Rancho 4" lift w/RS9000 shocks, 3" Body Lift, 35" BFG AT KO on Weld Wheels, Tactical Armor Group Bumper, Tuff Stuff 12,500 lb winch, Rancho Skid Plate, Flares, Magnaflow SS Dual exhaust, Dual Optima Red Tops, Pioneer Touch Screen Nav Unit, Pioneer DVD w/ 7" Drop Down, Planet Audio 5ch amp w/ Punch 10" Sub, Avatal Alarm w/ Remote Start, Backup Camera w/ 10" Monitor SOLD 5/20/12
tonydiv is offline   Reply With Quote
Old 10-18-2009, 09:02 PM   #7 (permalink)
Registered User
Default
Whats all this talk about draining the coolant? WTF are they smoking? I want some too! Anyway... the oil filter mounting gasket comes WITH the filter! duh!
RedRanger91XLT is offline   Reply With Quote
Old 10-24-2009, 11:39 AM   #8 (permalink)
Registered User
Default
In actuallity the oil filter mounts to a piece that is separate from the engine block. It is held onto the bottom of the block by 2 bolts and sealed with a gasket. There is alot of heat that goes through this part and its gasket. It is this gasket that has a small leak, not the oil filter itself. I am concerned if this is a common problem with the 4.6, and if anyone else has had this part fail. I have tried to look it up in the shop manuals but I don't see any reference to this part.
The problem is not with the oil filter but to the part that the oil filter mounts onto.
Old 10-28-2009, 02:30 PM   #9 (permalink)
ELVATO's Avatar
Super Mod
Default
Alright, finally found my manual CD.
The closest thing I can find that mentions a gasket for the oil filter mounting thing is in the instructions to remove the oil filter adaptor.
The instructions are different for a 4x2 and a 4x4. The 4x4 one seems simpler, since it only involves removing the front drive shaft, the lower radiator hose, and taking 4 bolts off of the oil filter adaptor. The 4x2 one involves removing the LH engine mount, and involves an engine hoist.
I can post instructions for either one. Again, sorry for the delay in replying.
__________________
Old 09-27-2011, 10:56 PM   #10 (permalink)
Registered User
Default
There is nothing on the door plaque that says R70 or R100 anything, and both are in the owner's manual Ford Aerostar Oil Filter Gaskets capacities listing. The VIN decode doesn't specify trans, as best i recall. I suppose I will need to get under it first - the type of ATF is different between the two, so I can't even shop first for the ATF, let alone filter and gasket! Oh Well!
ktrjones12 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
