Go Back   Ford Expedition Forum > Ford Expedition Forum > General Discussion
Register to remove these ads.
General Discussion
Brake Squeal
This is a discussion on Brake Squeal within the General Discussion forums, part of the Ford Expedition Forum category!
I took my truck in for squeeky brakes, and they said the pads are 50% but the rotors are to ...
Reply
Old 01-24-2004, 11:30 PM   #1 (permalink)
Guest
Posts: n/a
Default Brake Squeal
I took my truck in for squeeky brakes, and they said the pads are 50% but the rotors are to thin to turn. So i didnt replace them yet. What can i do next time so they wont squeel. Are dealer pads better about not squeeling, these pads were on there when i bought it.
Old 01-28-2004, 02:39 PM   #2 (permalink)
Guest
Posts: n/a
Default
Can a thin or warped brake rotor cause squeal.
Old 01-28-2004, 03:19 PM   #3 (permalink)
Default
Brake pad squeal usually comes from either
1. pebble/rock stuck between brake pad and rotor
2. brake pad vibrating/resonating in place, thus causing the squeal.
You can place some anti-squeal compound on the back of the pad to keep it from squealing, that might help. I use anti-seize compound since I've got more of that in the garage and does the same thing. It also keeps the brake pad from rusting itself onto the caliper.
To my knowledge, thin/warped rotors alone won't cause the squeal.
Keydo is offline   Reply With Quote
Old 01-28-2004, 04:26 PM   #4 (permalink)
rwinch's Avatar
Default
Another cause for "squealing" brakes is from "glazed" pads. Glazing can be caused by riding your brakes, or maybe forgetting to release the rear parking brakes, etc. Basically, it causes a shiny fused surface caused by overheating. Many times the only way to stop this is to get new pads unfortunately. :(
In terms of your rotors, I found the factory ones wear quite readily. I use an aftermarket brand, Brembo, and have been quite pleased with the wear rate, plus, they don't seem to rust as much. I am sure there are other good replacements as well. Note, I opted for the OEM replacement. Since I don't own a $160k 150mph+ race car, I don't see the need to put on the cross-drilled/slotted rotors that seem to be the rage (but then I shun the 22" open rims that are needed to show them off as well :p ).
__________________
'98 Red EB
BFG LT285/70/R17 T/A KO's
Hellwig Rear Anti-Sway Bar
Air Lift 1000 Series Rear Air Springs
Rancho RS9000X's Front/Rear
Rancho Streering Stb
K&N Drop-in
Brembo OEM Rotors
Raybestos Ceramic Pads
Mobile-1 Synthetic Motor Oil
Purolator Pure One Oil Filter
(Synthetic Everything Baby!!)
Kenwood 2-ways on all doors
(rear sub tbd soon..)
Sylvania Silverstars - Hdlmps & Fogs
2005 Fleetwood Niagara Camper (PU)
Tekonsha Prodigy Brake Controller
rwinch is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
