Expeditious
2007 Where in the Sam Hell is the flasher module??? I can hear it but have yet to see it. It's not listed in the owners manual in the section that mentions fuses and relays...
not sure if you found the problem.
here is the location for the relay flasher for an 03-06
the relay box is just behind the headlight switch, you need to get on your back on the driver side and look up toward the headlight switch there is two relay it also has a "cap" covering it. has you can see from the picture I replace it with an LED flasher relay.
not sure for 07, but check anyway.
Thanks I'll check tomorrow. I haven't had time to mess with it, I've been extra busy lately.
Same problem. I don’t know where is the flasher relay. You know the location??Since I installed the switchback LED's in the front turn signal, I have a bad case of rapid flash...There are two fixes. The first involve's a new flasher module, the other involves adding a load resistor. I'd rather switch out the relay.
