Go Back   Ford Expedition Forum > Ford Expedition Forum > General Discussion
Register to remove these ads.
General Discussion
Where do i put freon in my 2001 Expdition
This is a discussion on Where do i put freon in my 2001 Expdition within the General Discussion forums, part of the Ford Expedition Forum category!
I have a 2001 expy with the eddie bauer edition and the 5.4 Triton. I need to know where t ...
Reply
Old 06-14-2010, 09:24 PM   #1 (permalink)
Registered User
Default Where do i put freon in my 2001 Expdition
I have a 2001 expy with the eddie bauer edition and the 5.4 Triton. I need to know where t put some freon in the AC system, i think it is a little low on freon and and i cant figure out where to put some in at.
!keithnra is offline   Reply With Quote
Old 06-14-2010, 10:01 PM   #2 (permalink)
ELVATO's Avatar
Super Mod
Default
Should be something like that. This is where it is at in an 03+ Expy:
I forget who said it was elsewhere on the older ones. But, it should still be on the passenger side of the engine, probably with a black cap. You will probably find two caps. The refill kit should only fit the low side. Follow the instructions on the can.
Also, if you have rear A/C, make sure you have both the front and rear A/Cs set to max when refilling it.
__________________
I'm not responsible if you break something :)
ELVATO is offline   Reply With Quote
Old 06-14-2010, 10:40 PM   #3 (permalink)
walnuts4x4's Avatar
Default
on passenger side of firewall under a plastic cover with 2 wire harnesses, behind side of battery..... look up under all that for a silver cylinder and on it is the low port side for A/C follow lines to it... hard to see it the first time...
__________________
2012 Jeep Patriot....
Formerly a 99 expy with 11" lift and 37s...
walnuts4x4 is offline   Reply With Quote
Old 06-15-2010, 07:25 AM   #4 (permalink)
Registered User
Default
man u guys are awesome
Old 06-15-2010, 10:18 AM   #5 (permalink)
Default
and it takes 134a not freon
__________________
2000 EB,5.4 ,aw4x4, 20inch AR's,275/55/20,custom duals 2.5 with 3 inch rolled angle tips,altezza tails,
outkast is offline   Reply With Quote
Old 06-15-2010, 03:15 PM   #6 (permalink)
Registered User
Default
thats what i got. I found it today, i had to take the cover off the firewall to finally see it but i got some 134A in it and it is much better.
Old 09-12-2010, 06:07 PM   #7 (permalink)
Registered User
Default
hi guys, new to the forum. I'm trying to refill the r134a as well but can't locate the low side port. I believe I'm looking in the right area but still can't specifically see the valve stem. Could someone point me in the right direction?
jywu is offline   Reply With Quote
Old 09-12-2010, 08:02 PM   #8 (permalink)
JonnyBlaze's Avatar
Registered User
Default
I just recharged my ac a couple of days ago. Took 7 12oz cans to finally get cold. Thats $12.49 a can.
__________________
1997 Ford Expedition XLT w/ Leather. 6" Fabtech Suspension Lift. 315/75/16 BFG's Mounted on Aluminum Wheels. Polished K&N Cold Air Intake. TB Spacer. Flowmaster Dual Exhaust. LED Turn Signal Mirrors, Etc...
JonnyBlaze is offline   Reply With Quote
Old 09-12-2010, 08:40 PM   #9 (permalink)
Racenut's Avatar
Default
If you look at both of your pics, it wll be under that black metal braket that is mounted to the firewall holding wire harnesses. There are two I belive 8mm bolts that hold that bracket to the firewall and once you get that off you will be able to see it on the side of the reciver, just follow that metal line, take off the bracket and gently move it to the side, and it will be towards the motor side of the silver canister that is hidden by the bracket. ( if you look really close in the pics you can see the reciver[silver canister])
__________________
______________________
2002 Expy EB 5.4L 2wd
CAI
Flowmaster 70 series
Rear cat and Y pipe delete
Smoked corners, tails, and third brake light
2 Hella 500 FF behind grille
8000K HIDs Heads and Fogs
Soon to come
Shorty Headers
3.5" Fabtech 2wd lift kit
33" Tires
Racenut is offline   Reply With Quote
Old 09-16-2010, 05:58 AM   #10 (permalink)
Registered User
Default
okay sounds good. I'll be sure to take a picture of the actual port for future reference. Thanks for the help. Why in the world would Ford put it in such an inaccessible area?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
