Code P0430
hoopsta
I went to Autozone because my CEl came on and I got code P0430 this is a bad O2 or CAT CAUSED by misfire or vacuum leak or exhaust leak. I have pretty much ruled out Vacuum and exhaust leak which leaves me with the misfire I have been having.Can anyone tell me how to determine which cylinder is misfiring??? I have pulled every single one of the boots to do a visual inspection looking for water or oil in the well but they were all clean and dry. I am only getting the misfire at about 2000 RPM's when I accelerate and sometimes on the highway at around 72 MPH consistantly. I replaced the TPS about a month ago because the truck was losing power and bogging down when I stepped on the gas this fixed that problem but now I have this problem.
I don't want to chase my tail on this and was wondering if anyone can give me some advice
This is'nt a bad misfire yet it is just a slight bucking when I accelerate but I am worried it will get worse.
I am moving next month and need to fix this before I have to drive 4000 miles across country.
thanks in advance for any help.
2003 Expedition 4.6L XLT
71,000 miles
mohs00
michigan
id put some plugs in her if the havent been done and that should take care of it unless u have a bad coil but start with the plugs
