07-20-2011, 12:04 PM
#10 (permalink)
Registered User
EGR valve fitting
Register to remove these ads. It's free!
I've got a P0401 (insufficient EGR flow) code on my 97 Expedition with 5.4L engine and chasing down the problem too. I'm working from cheap and easy to the more expensive and time consuming options. I Seafoamed the engine to start. Figuring that'd clean some of the TB carbon out and possibly some vapor of the SeaFoam would recirc back up to the EGR. Didn't work, put idling better now anyway.
Yesterday I took off the DPFE and the two hoses coming from the EGR exhaust. There was carbon in hoses and DPFE. Hoses didn't have hole. I cleaned out the carbon deposits. The larger hose was somewhat collaped, so I was guessing that'd be the problem and went to Autozone to buy new hoses and DPFE.
I installed the new hoses first, just in case that fixed the problem (and I'd be able to return the new DPFE). Went for a test drive and the hose on the first port blew off. I'm now guessing the pressure is due to a lack of vacuum through the EGR, not a faulty DPFE.
I went to take off the EGR valve to clean it and the darn fitting from the exhaust side of the valve is siezed up tight. Anyone had this problem? Even if I took the TB off, the two 10mm bolts holding the TB to the EGR are siezed up. Its like both sides of the EGR have told me to buzz off. Anyone have this problem and what did you use to loosen it up?
