Go Back   Ford Expedition Forum > Ford Expedition Forum > Engine & Performance
Register to remove these ads.
Possible Throttle Body Problem
This is a discussion on Possible Throttle Body Problem within the Engine & Performance forums, part of the Ford Expedition Forum category!
Just today removed the throttle off the intake after removing the intake to replace intake gaskets on a 1999 Ford ...
Reply
Old 04-18-2011, 10:10 PM   #1 (permalink)
Registered User
Default Possible Throttle Body Problem
Just today removed the throttle off the intake after removing the intake to replace intake gaskets on a 1999 Ford Expedition Engine code L.
Re-installed the intake and cleaned the throttle body but didint use carb cleaner and used parts washer solution. Re-installed throttle body and started engine and engine will not run now unless throttle is half or almost wide open. Checked TP sensor and found that voltage reading at closed throttle was a little more then 1V and at wideopen throttle only 3.6V which should be 5V. Wondering if I did damage to the sensor or the throttle body itself which maybe causing this issue.|
Can someone help?
MatthewLugo85 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
