Go Back   Ford Expedition Forum > Ford Expedition Forum > Audio & Electronics
Register to remove these ads.
Audio & Electronics
Powercode Remote Start Accessory
This is a discussion on Powercode Remote Start Accessory within the Audio & Electronics forums, part of the Ford Expedition Forum category!
Question: I have the Powercode Remote Start on my 2010 Expedition Limited, and the owners guide references two modes that ...
Reply
Old 01-02-2011, 11:15 AM   #1 (permalink)
Registered User
Default Powercode Remote Start Accessory
Question: I have the Powercode Remote Start on my 2010 Expedition Limited, and the owners guide references two modes that it can work in.
First mode (set now from factory) is where you press the button for several seconds, doors lock and engine starts. You can remotely unlock the door, but the minute that you open any door (including the rear liftgate) the engine cuts off. You then have to enter the vehicle with the key and restart the engine.
Second mode is where you press the button and all of the above occurs, but you can unlock the vehicle, open the door without the engine cutting off, insert the key without touching the break pedal, turn the key to the normal "ON" position. Now you can put your foot on the brake and place the vehicle into gear. If you touch the brake pedal before inserting the key, then the motor will cut off as a safety/theft prevention.
Does anyone know how to reprogram the mode into Mode #2 without taking it to the dealer and paying them a service fee? Anyone know where I might could find this on-line somewhere? It is a real pain to have to restart the vehicle each time I use this feature to warm up the truck in the winter.
Thanks!
__________________
AndyGJ
Ford Vehicle History:
1968 Ford Mustang Coupe
1966 Ford Mustang Convertible (still in family)
1989 Ford Mustang LX 5.0 HB
1993 Ford Explorer Eddie Bauer
2000 Ford Expedition Eddie Bauer
2007 Ford Explorer Limited
2008 Ford Shelby GT Convertible #1676 (weekend toy)
2010 Ford Expedition Limited
Basically - I'm a Ford kinda guy!!
AndyGJ is offline   Reply With Quote
Old 01-02-2011, 12:20 PM   #2 (permalink)
Registered User
Default
I have the same thing in my 08, but it is in the second mode you are talking about. I did not know there were 2 modes and my manual did not mention it. Maybe there is a difference between an 08 and a 10?
cop on my back is offline   Reply With Quote
Old 01-02-2011, 02:10 PM   #3 (permalink)
Registered User
Default Found this on "Blue Oval Forum"
I went to the Blue Oval Forum and did some searching and came up with this detailed info:
Got my car (2011 Mustang) and did this. After a 'set back', it is now working!
I had inadvertanly held the remote fob button too long an reset the all of bank 2 to defaults. I was then getting a "tach not learned" error when I tried to remote start the car. I put bank 2 option 1 back to On (i.e. tachless) and got it working.
Once I 'fixed' it, here are the steps I did did:
The remote override button is 'easy' to find. It is taped to a harness, kind of right under the steering column. The remote module is tie wrapped above the kick panel (black box). The LED is tapped to the same harness and is about 1 inch from that button (between the button and the remote start module). I found it was easier to lay my back onto my drivers seat and then slide under the dash. Once you find the override button it is easy to press while sitting in the seat. But the LED is hard to see when sitting. So this is my recommended approach:
1. sit in the car with the door closed (has to be closed to enter programming mode)
2. press and hold brake pedal (keep it pressed)
3. turn ignition key to run (one position from start which lights up all the guages)
4. reach under the dash and press and hold the override button until horn beeps 3 times (about 10 seconds)
5. after the three beeps, release the override button
6. release brake pedal
7. open the door and now lay on your back to get your head under the dash (so you can see the LED light up; it won't be lit yet, but once it is, it will be obvious).
8. press and release override button (horn beeps 4 times, indicating bank 1)
9. press and release override button (horn beeps 5 times, indicating bank 2)
10. press brake (horn beeps 1 time, indicating option 1). This is "Tach Mode". I believe the LED should be lit. This is the one I had to play with. The true default is off, but I had to turn it On after I reset to defaults.
11. press brake (horn beeps 2 times, option 2). LED should be lit.
12. press brake (horn beeps 3 times, option 3). LED should be off.
13. press brake (horn beeps 4 times, option 4). LED should be lit.
14. press brake (horn beeps 5 times, option 5). LED should be off.
15. press brake (horn beeps 6 times, option 6). LED should be lit.
16. press brake (horn beeps 7 times, option 7). LED should be lit. (this is the one you need to change.
17. press and release the button on the remote start fob. the LED will go off.
18. press brake (horn beeps 8 times, option 8). LED should be off.
19. climb out and turn ignition key to off and take the key out.
20. close door and remote start your car. things should be great now.
This post has been edited by mbyers: 10 July 2010 - 09:58 AM
Here is the link for those that want the entire thread...
http://www.blueovalforums.com/forums...y/page__st__20
I'll try this today and repost my results after I'm finished....
__________________
AndyGJ
Old 01-02-2011, 05:41 PM   #4 (permalink)
Registered User
Smile This works!!!
I just did the above steps precisely and the Expedition now starts and does not cut off the motor when any door is opened!!
No more restarting on those cold mornings!!:)
Hope this helps some others with the same problem!
__________________
AndyGJ
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
