Go Back   Ford Expedition Forum > Ford Expedition Forum > Suspension
Register to remove these ads.
Suspension
Suspension Torque Specifications
This is a discussion on Suspension Torque Specifications within the Suspension forums, part of the Ford Expedition Forum category!
One ft-lb of torque is equivalent to 12 in-lbs. The below values are all in ft-lb unless otherwise stated. Hope ...
Like Tree1Likes
  • 1 Post By Jackmldog
Reply
Old 03-06-2011, 10:31 PM   #1 (permalink)
Jackmldog's Avatar
Post Suspension Torque Specifications
One ft-lb of torque is equivalent to 12 in-lbs. The below values are all in ft-lb unless otherwise stated. Hope this helps some people who don't have manuals.
Front Suspension
Air Shock
--Lower bolt/nut
---2003 and earlier models: 56 to 76
---2004 and 2005 models: 293
---2006 and later models: 350
--Upper nut: 37 to 44
Balljoints
--Lower balljoint to knuckle nut: 83 to 112
--Upper balljoint to knuckle nut: 57 to 76
Lower control arm to frame pivot bolts/nuts
--2003 and earlier models: 197 to 241
--2004 through 2006 models: 199
--2007 and later models: 256
Shock absorber
--Lower nuts (2WD): 22 to 29
--Lower bolt/nut (4WD)
---1999 and earlier models: 56 to 76
---2000 and later models: 65 to 87
--Upper nut: 35 to 46
Sway Bar
--Bracket to frame bolts: 19 to 25
--Link nut: 16 to 21
Upper Control arm to frame picot bolt nuts: 83 to 112
Hub and bearing assembly bolts: 110 to 148
Rear Suspension
Lower control arm to frame nuts
--2003 through 2006 models: 184
--2007 and 2008 models: 221
--2009 and later models: 266
Lower control arm to knuckle nut
--2003 through 2006 models: 295
--2007 and 2008 models: 350
--2009 and later models: 406
Upper control arm to frame
---Forward nut: 111
---Rearward nut: 184
--2009 and later models: 165
Upper control arm to knuckle nut
--2003 through 2006 models: 111
--2007 and later models: 76
Trailing arms (2007 and later models)
--Lower trailing arm to frame: 203
--Lower trailing arm to knuckle: 76
--Upper trailing arm to frame: 203
--Upper trailing arm to knuckle
---Bolt: 184
---Nut: 76
Shock absorber mounting bolt 2002 and earlier (lower and upper): 63 to 84
Shock absorber/spring assembly upper mounting nuts 2003 and later: 24
Shock absorber/spring lower mounting bolt
--2003 models: 350
--2004 and 2005 models: 332
--2006 models: 295
-- 2007 and later models: 406
Shock Rod nut
--2003 through 2006 models: 22
--2007 and later models: 41
Stabilizer bar link nuts
--2002 and earlier models: 63 to 84
--2003 through 2005 models: 66
--2006 models: 59
--2007 and later models: 46
Stabilizer bar bushing bracket nuts
--2003 through 2005 models: 30
--2006 models: 41
--2007 and later models: 35
Toe link to frame nut
--2003 and 2004 models: 59
--2005 models: 66
--2006 models: 52
--2007 and later models: 203
Toe link to knuckle bolt or nut
--2003 through 2006 models: 41
--2007 and later models: 165
Toe link adjuster lock nut: 85
Wheel bearing/hub assembly mounting bolts
--2003 through 2008 models: 136
--2009 and later models: 129
Steering
Airbag module retaining screws: 89 to 115 in-lbs
Idler arm
--Idler arm bracket to frame bolts: 125 to 169
--Idler arm to center link ballstud nut: 56 to 75
Intermediate shaft to steering gear input shaft pinch bolt: 30 to 40
Pitman arm
--Pitman arm to steering gear nut: 173 to 233
--Pitman arm to center link ballstud nut: 56 to 75
Power Steering pump mounting bolts: 15 to 20
Steering gear to frame mounting bolts
--2002 and earlier: 50 to 67
--2003 to 2006 models: 11
--2007 and later models: 325
Steering wheel bolt: 23 to 32
Tie Rod Ends
--Inner tie rod end to center link ballstud nut: 56 to 75
--Outer tie rod end to steering knuckle ballstud nut: 56 to 75
2007EXPYBLUEEB likes this.
Jackmldog is offline   Reply With Quote
Old 04-21-2011, 01:59 AM   #2 (permalink)
GXPY's Avatar
Registered User
Default
Awesome, going to install the lift on my '09 Friday and was in desperate need of torque specs. Thank you!
GXPY is offline   Reply With Quote
Old 04-13-2012, 02:27 PM   #3 (permalink)
Default
Do you have the torque numbers for lower and up upper trailing arms bolts for my 2000?
__________________
2000 XLT, 4.6L Black
1998 XLT, 5.4L White (former police vehicle) - headed to the junk yard soon.
98EXPY 5-0 is offline   Reply With Quote
Reply
Bookmarks
Tags
steering, suspension, torque specs
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
