Go Back   Ford Expedition Forum > Ford Expedition Forum > Transmission & Drive train
Register to remove these ads.
99 EB transmission and rear end.
This is a discussion on 99 EB transmission and rear end. within the Transmission & Drive train forums, part of the Ford Expedition Forum category!
I'm new to this site. totally confused about fords setup. I have a 99 Ford Expedition 2WD 5.4 Eddie Beaur ...
Reply
Old 10-06-2011, 02:38 AM   #1 (permalink)
Registered User
Default 99 EB transmission and rear end.
I'm new to this site. totally confused about fords setup. I have a 99 Ford Expedition 2WD 5.4 Eddie Beaur edition. Anyone know what type of transmission comes on it? The car has 140k miles.
Planning on a 4k mile road trip towing a 20ft trailer. So I'm going to have to do some serious maintenance . Any help would be appreciated
Thanks
ASIANREDNECK is offline   Reply With Quote
Old 10-07-2011, 08:30 PM   #2 (permalink)
Registered User
Default
With 2WD most likely an E40D,
1st. get a new overflow tank cap at 130K mine failed and entire cooling system failed,it needs correct pressure/venting. replace t-stat, (STAY OEM on T-Stat temp..),and then get the fluids changed, if you have time/$ change diff fluid also, my rear diff failed at 150ishK, a little extraordinary maint. esp. when towing is well worth the X-tra time/$!!!
dgna5 is offline   Reply With Quote
Old 10-08-2011, 10:44 PM   #3 (permalink)
Default
the e40d/4r100 comes with the 5.4 the 4r70w came with the 4.6 and since you have the 5.4 most likely you have the 4r100/e40d(same trans just new naming convention used)
__________________
'97 eddie bauer
goodyear wrangler sr-a's standing at a proud 31"
Sylvania silverstar ultra's
Bosch Icon One-Piece 22" Wipers
Dynomax 17733 (direct weld in of original muffler)
FUTURE
05-10 navigator/expeidition power fold/heated/turn signal mirrors
trdragons44 is offline   Reply With Quote
Old 10-10-2011, 09:49 PM   #4 (permalink)
Registered User
Default
do they make helper springs for expedition with air ride?
Old 10-10-2011, 11:57 PM   #5 (permalink)
Registered User
Default
ok here is a picture of my suspension. I have springs and air suspension?
Old 10-13-2011, 02:54 AM   #6 (permalink)
Registered User
Default
Does the e40d come with trans cooler?
what type of transmission fluid do you guys recommend ? How many qrts do I need if I drain the torque converter and pan?
Thanks
Old 10-19-2011, 10:56 PM   #7 (permalink)
Default
Looks like you have regular spring suspension the air ride would have a airbag where the coil spring is. The trans cooler separate from the radiator is only there if you have the hd tow package<-consists of heavy duty radiator, 7-way trailer plug, drop hitch, trans cooler. if you look at the front of your truck there should be two little radiator looking things, if there is only one on the drivers side(power steering cooler) you do not have a secondary trans cooler. tranny fluid should be whats listed in the owners manual usually mercon and i believe it takes upwards of 18 quarts if you drain the TC. hope this helps
__________________
'97 eddie bauer
FUTURE
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
