2022 stealth edition wheel change with Timberline
nobody
Saudi Arabia
I have a 2022 stealth edition (4WD with no CCD suspension) and the ride can be better, i had a 2012 F150 XLT and that was driving on clouds especially on the Highway.
so my idea at the moment since i like the look and color of the stealth wheels (285/45/22) is to get me a timberline wheels since they are black and they are 18 in ( I am thinking of 275/65/18). any one tried this? i almost do not drive off road but mainly city and highway and we do not have snow here.
anyone can recommend 18 in wheels that will fit if the Timberline is bad choice?
Thank you
GixxerJasen
DFW TX
I believe they should fit, from one Expy to another shoudln't be an issue. You should also be able to fit F150 wheels too if you trim the ends of the rear axles to fit the center caps. I can attest that the move from 22's to 18's is a huge improvement in ride comfort especially on rough roads.
Not a 2022 but...275/70 R18
joeblade06
CT, USA
Similar to Nobody's question. I want to have a set of 18" for my '22 limited to swap during the winter from my 20"s. There are more salvage and refurbished 4th Gneration wheels now available so the cost will not be OEM crazy. Has anyone done a dedicated set of winter tires on 18's from 20? if yes, did you go with the 275/65/18 and with which rim (NL1Z1007C:from XLT or NL1Z1007G:from Timberline)? Thanks in advance
oelkersbrian
