Let's See Those Lifted / Big Tire Gen 4s!!
lefty hack
Vegas
I’ve had my ‘18 max Plati since ‘19
Lifted 3”, RCI skid plates, Kingdom Overlanding roof rack(awesome) Vision 18” rims(discount tires), Nitto grappler tires. I just ordered a Raptor grille and DEchroming as we speak. I use it hunting and in the Utah snow. Does great.
Chonchberry
Tri-Cities, TN
2020 Max Limited
24x9 +30mm STR SNOWFLAKE (GM pattern) drilled to 6-135
35x12.5 Fortune RT
3/2 ReadyLift
Rough Country rear components to center rear wheel.
I’ve had it like this for a couple weeks. Probably have 1k miles on it. Slight rub on inside of front passenger wheel well that I need to take care of still. Only noticeable when backing up and only rubs with wheel 1/2 way to the left. I’m going to get under it this weekend to adjust the liner.
AofJ
NV
@Lumberjack - Did you have to mod anything or was it a plug and play? If you had to mod, what did you have to do?
jrsharp06
