Auto headlights
michigan
Is there a way to disconnect the auto headlight activation when putting truck in gear for 2010 limited? Be it drive or reverse, day or night when car goes in gear the headlights come on.
99WhiteC5Coupe
On my 2015 Expedition Limited with auto headlamps, the switch has four positions:
Auto
Parking lamps on (manual)
Head lamps on (manual)
Auto and exterior lamps shut off (manual)
Does you switch have similar positions? You could turn the lamps off manually, or turn on the headlamps when you feel they are needed.
Is the solar sensor on the top, middle of the dash covered or damaged?
R
michigan
No even with the light switch in the off position the head lights come on immediately when i put the vehicle in gear. I have to check for placement of the sensor.
99WhiteC5Coupe
On mine - turning the switch to off stops the headlamps from turning on, not matter what the ambient light is.
It sounds as though there is an electrical short in the switch?
djahmed786
