blbikerood
I thought I had read that somewhere. Some key that turns it up level with the rear end?? Thanks!
Use a 18mm socket and breaker bar.
You can do a torsion twist . I think thats what you are thinking.
Lay under the b pillar and you will see the round bar coming from the front. follow it back and youll see an arm with a bolt. on the passenger side and another bolt across from it coming down on the drivers side. if you loosen the bolt the front of your truck comes down if you tighten it, it goes up. I sprayed some WD-40 on the bolt about 10 minutes before I attempted the twist.
I got almost 2 inches when I did mine on my 98 Eddie Bauer.
__________________
what they said.... but another hint is make measurements from ground to fender... then put a mark on bolts before you turn them so you can turn them equally... then remeasure fender to make sure level... then drive down some bumpy roads and remeasure to make sure your level...
if i hit a drive way just and alittle fast i get some rubbing on the running board
Take off the running boards. Sell them on Craigslist. Problem solved.
dose anyone know if there are 2 inch high springs. i did a torsion crank. 2". and i want the rear higher. i have never liked blocks on leafs or spacers on springs. so i was wondering if there were any bigger springs i can put in. or if some jeep wrangler springs would fit. just an option.
