Glass lift gate unlatches sporadically
RichCam
Charlotte
My glass lift gate has started unlatching when I get out of the car as I walk away. Which means the lights remain on..
Since there is not a remote button for this, I have no idea what can be causing this.
Any ideas?
2020-MAX-Limited
Colorado USA
Physical latch adjustment is out of whack. When you close the lift gate, is it snugly fitting with no movement? Perhaps it has been slammed a few times causing adjustment to go out of spec.
techdude99
US
Agree with @2020-MAX-Limited If the light is staying on, the circuit is open it could be physical or a bad wire, which I doubt.
The latch may have moved out of alignment or the electrical mechanism might be broken. Just to confirm, is it the lift gate or the lift gate glass?
@RichCam check a few things:
1. Are you are hearing a solid 'click' when it closes. Look for misaligned panels or obstructions.
2. Inspect the both parts of the latching mechanism to see if it moved from the original location or is loose.
3. If you have a plastic automotive interior trim removal kit, use a towel or rubber pad so you don't scratch the paint, and gently take one of the pry tools to pull on the gate or glass
Let us know what happens.
