JamusDemus
So I was wondering what you guys have programmed using FORScan?
I changed mine to six flashes. I did mine via the Hexidecimal as-built method. Looking into this again (F-150 forums), looks like you can do it through the comfort mode.I did mostly the same things I did on my 2015 F-150.
* Disabled startup chimes
* Disabled double-horn honk when leaving with truck still running
* Disabled chimes - vehicle running with door open
* Changed tire circumference to fix slight speed offset due to wheel size difference
* Changed battery target state of charge from 80% to 95%
* Disabled all the seat belt minders
* Enabled engine/transmission temperature numbers above sweep gauges
I still want to change from 3 blinker activations when temporarily moving the turn signal to 7 activations, but I haven't found an option for that yet.
True but most people are too lazy to search. So, we just repeat and repeatWhole threads on this.
how? I can't find that in documents but eagerly need* Changed battery target state of charge from 80% to 95%
Look in the Forscan NOT AS Built sections. You can also search. It's there. I have not done it yet until I see if there are any side effects. Some things like Auto Start/Stop changes can cause some.how? I can't find that in documents but eagerly need
