2005 Expedition timing chain kit replacement. Can a (fairly capable) newbie do it? (moral support thread)
proftomda
georgia
It sounds like you are a capable guy so I would ask 2 questions. 1. Do you have a decent place to work on it and 2. Do you possess patience when working on mechanical things? With all the information available to do this job, it really a matter of following directions carefully. I did this job about 5 years ago on my sons truck. I methodically removed every part and laid them out on tables in the order removed and it still took me multiple days. Truck runs perfectly with that improved oil pump and cast iron timing tensioners. I did not do the roller followers because the truck only had 100k on it. You definately want to do those at your mileage. 5W-30 oil is this engines best friend.
clbaseballa25
Phoenix, AZ
I found this through a Google search and here’s my situation:
2006 Expedition Limited 131k. Paint is faded from AZ sun and front seats are torn. It ran smooth for 3yrs and I have only put about 4K/yr on it as I have a short work commute and only really use it for towing my motorcycles to the local track(10mi round trip) other than commuting.
Back in Dec while driving to work I swerved to avoid some road debris and afterwards I couldn’t accelerate above 50mph. I got a check engine light and shut down the motor. I ran the codes and got 3 misfire codes but stupidly cleared them and haven’t been able to get the codes to come back as the engine will crank but not start.
I noticed an oil leak from the passenger side VCT and replaced it. Still doesn’t start. I had a mobile mechanic look at it and he couldn’t determine root cause only that there was no spark. He determined it might be PCM but couldn’t say for certain. Since then I have done an oil change, changed crank angle sensor and cleaned throttle body and both cam position sensors. I had another mobile mechanic look at it and he determined it’s low compression and most likely timing chain issues(possibly skipped). Before the breakdown it ran fine however I noticed a rattling noise from passenger side that I thought was alternator but now think it was the chain tensioner.
Like OP I can do replacement work but wouldn’t know what to check while doing it. I have done a timing belt before but not a chain. I am willing to put maybe $1500 into this as due to the paint and front seats it’s worth maybe $3-4k max in running condition so no point paying $5k+ for a quality rebuilt motor.
That said, where would I go to get the timing chain set? I found this kit on Amazon and it looks like OEM parts but a few reviews have said it is missing some of the parts needed: https://a.co/d/5dPjNOv
SafariGoneWrong
I’ve been using Varsity Ford Parts online and have been very pleased. Of course you have to get the individual components but at least you know it’s Ford.
clbaseballa25
Phoenix, AZ
2 days in of taking my sweet time and accumulating a few tools in the process and have the timing cover off.
It looks like it’s just the passenger side guide that failed and don’t see any other damage, but haven’t dropped the oil pan yet. I have done an oil change while it was sitting and didn’t see any shavings in there, however, it looks like the video suggests changing from 5w20 to 5w30.
In addition I need a new A/C compressor and was able to get the passenger side head cover off without evacuating the system, but now need to do that before I go any further.
Other than dropping the oil pan and pressing on the rocker covers to see if any are bad what else should I check while in there?
I also pulled a couple of cam caps on the passenger side and saw what looks like normal wear and tear with no major scoring.
Here’s a few pics
proftomda
georgia
Hard to tell by the photos but does the 2nd to the bottom cam lobe in the picture have a groove on it or is smooth and flat across the lobe? If smooth and flat, everything else appears normal for the mileage. Definately go with 5w-30 oil, keep that oil level full and no more than 5,000 miles oil changes.
mbtech2003
capecod
clbaseballa25
Phoenix, AZ
As I posted in my other thread it turned out the damage was beyond what I was willing to repair and sadly had to cut my losses. If the paint and front seats were in better condition it may have been worth throwing another $4k in a junkyard engine with a 2yr warranty and having the shop put the new timing parts on but even at 131k I imagine the max value would’ve been $4k in that condition.
Thankfully I was able to return a few of the parts that were bolted on but I’m still stuck with $800 in labor and $1000 in parts I can’t return(timing kit and camshafts) and will be lucky to resell for half of what I paid.
Oh well, at least I got 3yrs of service even if I only put 13k on it and ended with 131k on the clock. Here’s the fondest memory of ol’ Expy who when she ran could haul my bikes to the track with the greatest of ease…
clbaseballa25
Phoenix, AZ
Apparently the metal from the end of the cam that sheared off got in the bottom end and resulted in enough damage that a rebuild was necessary
