Mirror Tap on 2024
armoredsaint
Ohio
Just got another new Expedition Limited Stealth today in Dark Matter, the layout of the cover is different but wanted to share just in case others need info, it was easy using my same mirror tap, black with black and red with white, took my 60 seconds and it does turn off with ignition too.IMG_1947.JPEGIMG_1943.JPEGIMG_1950.JPEGIMG_1948.jpg
armoredsaint
armoredsaint
Ohio
Pretty truck… thereviscactusllyba tap kit on Amazon.
Also check out FitCamX as part of the camera, they have a super clean adapter and unit looks OEM
that looks cool, but seems limited details and i assume the F-150 might be the closest fit?
mikemuze
Bradenton FL
doing the same on a 2023 KR.
How do I remove the cover - where to pull/pry first so I don't break anything?
is the wiring the same as the '24?
Thanks all...
