2016 driver's window problem
vwspammo
About 2 months ago the driver's window wouldn't go down. It didn't make any noise when you pushed the up or down button. I replaced the window switch cluster with an OEM switch and it worked again, until I closed the door. I looked at the schematic and there is only one power wire that goes into the driver's switch and then goes to all other windows. The other windows always work. It was sporadic, but my wife didn't want to have the window stuck down.
I was wondering if it could be the regulator?
