rebelmp
Hey all,
I've got an 03 eb 5.4. Truck started overheating on the highway.Put in new t-stat, water pump, fan clutch, and serpentine belt then took it in for a full system flush.
Runs perfect on regular roads. Once I'm on the highway, around 70 mph, she starts overheating. If I get off highway, she stays hot till I turn her off for hhalf an hour or so, then runs fine again.
Had the mechanics check. Head gasket is fine, and truck passes a compression test.
Doesn't need ac on to overheat, but that speeds the process up (doesn't overheat with ac on high on regular roads).
I'm completely lost at where to go from here. Any thoughts?
