Johnb1019
hello I have a problem and have no clue where to look at, i have no reverse lights when i shift it into reverse, Ive check the bulb socket with my tester with the parking brake on and the ignition on but not running, is there a fuse or a relay that controls the signal? also I have been thru the column a couple times fixing the loose shifter, so if something came loose or not i dont know what to look for, any ideas?? thanks, cause i have LED taillights, 3rd brake light, and a 60" LED lightbar coming that lights up in reverse also,.
