Go Back   Ford Expedition Forum > Ford Expedition Forum > Transmission & Drive train
Register to remove these ads.
Clunking Sound from front drivers side
This is a discussion on Clunking Sound from front drivers side within the Transmission & Drive train forums, part of the Ford Expedition Forum category!
Okay, so I'm stumped. I am getting a clunking noise coming from drivers side. I've changed the tie rods, the ...
Reply
Old 03-29-2010, 04:31 PM   #1 (permalink)
Registered User
Exclamation Clunking Sound from front drivers side
Okay, so I'm stumped. I am getting a clunking noise coming from drivers side. I've changed the tie rods, the cv axle, and the wheel hub twice! Still clunking. It does do it all the time, but once I hit a bump, then the clunking starts.
The clunking stops when I get over 30mph. I've put the vehicle in neutral and let the vehicle coast - still clunks.
Also, when I turn on 4x4, the clunking stops BUT the vehicle pulls super hard to the right. So I have no idea.
Earlier today, I jacked up the front of my vehicle, placed it in neutral and spun both wheels by hand. The right wheel turns perfectly fine. The left wheel has some sort of resistance. I checked the u joints.
I got under the vehicle while the wheels were on the ground and the left axle has some sort of play In it. If I grab it by hand and attempt to spin, it actually moves like a 1/2 inch both ways. The right side has no play at all.
Anyone help me out? Oh when going highway speeds, no sounds are heard. Idk what's wrong.
Help would be greatly appreciated.
burksfinancial is offline   Reply With Quote
Old 03-29-2010, 08:49 PM   #2 (permalink)
Default
maybe the bearings. could be goin out and need to be replaced. also, if you have the weights on the inside of the rim and not the outside, one might be bent and rubbing. but i guess that would be more of a clicking.
__________________
01 EB. 4" Rancho Lift. 35" Nitto AT on 18x9 KMC. Warn hidden winch mount with XRC8000 winch.
nvycrmn is offline   Reply With Quote
Old 03-29-2010, 09:09 PM   #3 (permalink)
Stoned06's Avatar
Default
Does it also happen on turns? The only clunk I am aware of is the dreaded lower control arm clunk associated with the camber bolt that afflicts the older F150's (1997-2003). There is an elongated hole that has the round camber bolt going through it. At full lock, it would "clunk" when the bolt slightly shifted in the hole. There are shops that sell "Clunk Washers" that fix the slop in the adjustment.
__________________
2006 EB
Stoned06 is offline   Reply With Quote
Old 03-29-2010, 09:15 PM   #4 (permalink)
Registered User
Default
Thanks. I just replaced the hub twice in last month to be sure.
It doesn't happen when turning, it initially starts when I hit a bump. But continues until I stop the truck for a while. Then once I get back in, the clunking is non existent until I hit a bump again.
Such a weird situation
Old 03-29-2010, 11:26 PM   #5 (permalink)
tritonman5.4's Avatar
Default
dude my expo is doin the same thing from the driver side front end
tritonman5.4 is offline   Reply With Quote
Old 03-29-2010, 11:49 PM   #6 (permalink)
Registered User
Default clunking noise
its your stabilizer bar bushings
trent1214 is offline   Reply With Quote
Old 03-30-2010, 12:08 AM   #7 (permalink)
Registered User
Default
Bushings wouldn't cause hesitation/resistence when turning the wheel while its jacked up lol
I think it has something to do with the diff.
Old 03-30-2010, 11:44 AM   #8 (permalink)
Registered User
Default
This is where I attempt to turn the axle. It moves liek 1/2 inch both ways. Not sure if its supposed to do that. Any one know?
I dont see anything but an axle shaft and retainer clip. So --- the clunking must be the differential?
I'm not understanding why It would only have resistance on the LH side and not the right....if the gears were messed up - why would I only hear and feel it on the left?
Old 04-21-2010, 06:47 PM   #9 (permalink)
Registered User
Default
Ok so I finally found out the issue with my truck....kinda sorta.
I think the truck is attempting to switchin into 4x4 like constantly.
I removed fuse 104 to disable the 4x4 clutch, and VOILA! NO clunking what so ever....obviously 4x4 is disabled now. But I have no idea what it would be this way.
Starting to love my truck again.
Old 04-22-2010, 07:03 PM   #10 (permalink)
Default
where or how did you get the diagrams?
glad you were able to sorta fix it.
__________________
STOCK / WORK IN PROGRESS
grantikal is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
