Lift/level
RenegadeBad_Dog
South Carolina
Anyone know if this would even be worth buying? It's only a 0.5 inch level and I'm worried that that isn't big enough to even make a noticeable difference.ece92424be3e45145b6aa0d149a1883b.jpg
Sent from my SM-G973U using Tapatalk
Super Moderator
Super Moderator
I think it would be noticeable, but small.
Vancouver Bob
Vancouver, WA
What is it that you're wanting to achieve? Reduce rake? Increase ground clearance? Bigger tires? All of the above? :)
RenegadeBad_Dog
RenegadeBad_Dog
South Carolina
Eventually all the above. I was thinking about getting the bilstein 5100 eventually but the deal I these are pretty good so I was thinking temporarily just to give it a little different look for the time being. Some day I would like to do a 3 inch lift all around with some bigger trims and tires but that won't be for a while.
Kjhawkeye1
River Falls, WI
My 2 cents... I wouldn't be in too big of a rush and make a temporary change that you'll need to undo later. Get what you really want so that you're making progress towards your end goal.
I would agree with this. I waited 2 years and got the setup I was looking for and saved my $ to install all new shocks (front/back) at the same time rather than piece it together.
montazuma
I have the 3/2 lift/leveling kit installed on my 2007. Even with 34” tires you can barely notice that its modified. It has the look of a standard F150 4x4. Ground clearance from the stock running boards can’t be more than a 1/2” higher than a stock F150 4x4. I can’t imagine that you’d realize much difference with a 1/2” front leveling kit. Unless you’re doing it for rake issues I’d pass. And I think you’ll get more performance gain from better brakes and shocks than you will from leveling it?
RenegadeBad_Dog
RenegadeBad_Dog
South Carolina
Thank you all you the input! I've definitely decided to just wait and try and do it all at once instead of dealing with the headaches of changing it down the road.
Presley98
