A year that DOESN'T have massive transmission issues?
TravisExpy
McKinney
We bought a 2019 Max with max tow package in December. We were aware that the transmission had been replaced when the original owner traded it in and clearly should have been more concerned about that. We tried pulling our 3k lb trailer last weekend and the transmission was getting too hot. Service center could replicate the issue (not trailer attached when they had it) and they said it must have been overfilled when it was replaced but should be fine now (but they didn't do anything to it because level was normal when they tested it). This weekend we took test run down the highway with the trailer. It took a whopping 15 minutes to get transmission temp to 244 degrees and the coolant temp to 230. A different dealership it taking it in to check it later this week but from what I'm reading this is a common issue. Lovely. Is there a more current year that they have fixed this in? I'll give them a chance to fix it but I'm not keeping it if I'm going to constantly fight the transmission...but I LOOOVE my expy!!
Mediamonkey11
Super Moderator
Super Moderator
Enumclaw, WA
If I'm not mistaken, that coolant temp is higher than it should be. Curious as to what they find, maybe a cooling issue overall vs just a trans one...
Hellwig
replace the thermostat with the 180F model.
DavidCola
South Carolina
I have a 2019 and had all sorts of issues with the engine's temperature spiking hot-but not overheating. The original thermostats are fickle. I replaced and no more issues.
anupe
