rwmorrisonjr
After I changed my water pump, hoses, t-stat, and radiator cap in August, I noticed I was starting to lose coolant on a regular basis. Now that it's warm out, I finally got a chance to look under the hood and here's what I found. Guess the gasket began failing after all the work brought the system back up to normal pressure. Thankfully I can buy just the gaskets and not need to replace the entire bypass pipe assembly. Parts on order from Amazon, might be this weekend's project!
Leaking bypass gasket:
Coolant puddle on garage floor:
