CD player/USB interface..
ntpwsa
ohio
I own a 2020 Platinum….wondering if there is a consensus on a model and maufacturer
Of a CD deck/Player that uses a USB for the interface ?
RW
nationalgallery
I'd stay away from the ones with a hand crank on the side. :)
I have hundreds of CDs, so I do miss having a CD player in the car.
Mr Big
Tampa Bay, Florida USA
I copied about 25 of my CDs to a thumb drive. They play great and sound super quality. I can shuffle, play one song, repeat or play the entire album. It also shows the album cover on the screen
NevadaGeo
I have done the same... copy all my music on a small thumb drive and it is inserted in the front console. As Mr Big says, can sort, mix and alphabetize artists and albums. Hell, I remember the days when it was an expensive option to just have a radio installed... Never had to deal with the crank phonograph option though....... :D
Super Moderator
Super Moderator
Rip the CD's to MP3 and play them like others have said. Works great. Leave it inserted all the time, because it does take a second to index. I am not aware of a plug in CD Drive working. The issue would not be it working but handling bouncing down the road. Portable CD Drives for computers are designed to be sitting on a desk(flat non-moving surface), and won't have the motion isolation to handle a moving vehicle and bumps.
scottdm
Western PA
RW
I 2nd the thumb drive idea, but if you really want a CD player, the 2018 models still had a CD player in the dash that you could likely retrofit into your 2020.
bzav
I ripped my CDs to wma format and play them using USB drive. But it only plays them alphabetically by song. How do you get the system to recognize albums and artists?
VBreithaupt
You can get a adaptor for your CD player headphone jack that goes to USB and then power source plug to backside console usb. It works but is somewhat cumbersome. I use that setup once in a while if I want to pull a CD I haven't heard in a long time.
purevw
Not sure why you would choose wma over the more popular formats, but ripping is the beginning of the process; not the entire process. The info concerning genre, artist, album, etc. is contained in the meta-tags of the file. CDs generally don't have meta-tags. So if it's ripped from a CD, there will be no info. There are programs that can sample your ripped files and likely find the correct meta info and insert that info into the file so that your player can read it. MusicBrainz Picard is a good one. I don't use Windows, but I believe there is a Windows version of Picard. For future purchases, you might investigate HD audio downloads. They are not cheap or small (1.2GB per "album"), but generally have double the resolution of an audio CD. HDTracks is just one of many services for high quality audio.
Staff online
imjuststeven
