GD part number tail light pigtail
abnmike
south carolina
After hours of searching I can’t find this part. Anytime I think I do it says not compatible.
2017 Expedition
Left rear taillight. I have the socket that holds the bulb. I need this piece that plugs into the socket and delivers the juice.
Sometimes the light/blinker works. Sometimes it doesn’t. Replaced socket and bulb. This has to be culprit.
There are three wires to this connector.
Hamfisted
Ft Lauderdale
It doesn't look too bad off. Did you put a test light on each terminal to test it ? If it really is bad you might end up go to a salvage yard and cutting out what you need.
Motorcraft Plug on Amazon
A
abnmike
south carolina
There’s nothing else it can be. Prefer to order a new one vs get another potentially bad one.
Plus I can test it and it can work. Then later it stops working. I can get it working, bundle it all up, it still works. Turn off truck. Turn on next day. Doesn't work. Or maybe it does work, then it quits working.
Somewhere a wire in that area is wonky so the only fix I can see is a new pigtail connector, but can't find the right one.
99WhiteC5Coupe
2017 Expedition
Did you go to a Ford part’s department with your VIN to see if the rear lamp harness is available (or a pigtail)?
jessiev
