Tail signal lights
HILLY
Greenville, SC
Glad to hear that has worked out for you. I'd be interested in seeing pictures of how and what you have done to get this working. I was also looking at this recently and thinking another way to get individual signals would be to tap into the 7-pin trailer harness.
For the turn signals, sounds like you tapped into the mirrors and ran the signal wire from the front door back to the tail?
Clever to take the signal from the CHL to have a dedicated stop light.
G
gural
Poland / Europe
i some free moment i will add also picures
so for the trailer you can take from from lamps or mirror the signal for separate turns
I took it from mirrors not to put extra wiring in the engine chamber
You dont need to get to doors
I took it from wiring just where it goes from car to doors (easy way to plug in)
Regarding stop light in old cars it was easier becouse the instalation did not check the volatage on the instalation, new cars do it - this is the reason i putted led bulbs (those are 1 A) instead od normal one (those are 2 A)
G
gural
Poland / Europe
for change in upper socked i bought a
in in i putted the orginal revers + added signal for turn
G
gural
Poland / Europe
Normalnie Light could be a Little bit shiny. I am thinking about addidng żeber diod to mąkę ten weeker
mikeydoh
