Hey guys new to the forum and could really use some help.
I have a 2008 expedition limited that has a intermittent crank but no start issue. There doesnt seem to be a pattern with the issue it will do it hot or cold. It's my wife's car so naturally it never does it when I am around except yesterday when we are running late for a funeral. I did a couple test before we had to leave and this is what I got. It has fuel pressure at the rail, has crank input, has power to the cop's(didnt verify spark). Using a test light I checked for power at the fuel injectors and got nothing KOEO.
From what I understand with KOEO there should power at the injectors and the PCM switches ground to fire when running. Is that correct on this model? Because what is happening is when the key is turned to run for about 2 seconds I get power to the injector connector then it goes off. Once you try to crank the vehicle you get constant power. That's what's happened when the expy starts. I did the same test and didnt have power at all when it would not start but I was kinda rushed and I'm kinda second guessing myself.
