2003 Expedition XLT 4.6L 4x4 Airbag light stays on after starting the truck
Germany, Bavaria
The airbag light stays on without flashing a code and the fuse 19 for RCM is blown. After setting a new 10A fuse it blows directly after I started the truck. I tryed stronger fuses (30A will hold) to get a connection to the RCM with "Forscan", but will also not find any error code. Forsys Pro states, it lost connection or can't to the RCM module. Is the module toast and where is it located? Which connections can I test to get it run. Light appears after battery was drained two times in a short. I jump started the truck, drove around for 30min and then was checking some things without running but lights and radio on and it drained a second time. After the next jumpstart the airbag light stayed on. Maybe it has nothing to dowith it.
