2004 ford expedition start
Hamfisted
Ft Lauderdale
Your security LED isn't high speed flashing right ? (That LED in the middle top of the dash ). If it was rapid flashing when you tried to start it that means it doesn't like the key you're using. Try a different key. Or you can check the fuel pump inertia safety switch back there in the left rear quarter panel. Instructions are in your owners manual. Just check that the red button on top is pushed down and not popped up. Was it running good when you parked it ? Any history of this fail to start issue ?
