2008 Expedition Forscan Decoding
SPDR
Nebraska
Just started decoding the Ford modules in Forscan to solve some cosmic retribution level electrical gremlins.
Anyone with a 2008 Ford Expedition want to drop their vin number into the motorcraft as built site and then post the results you get to help speed things up?
Work in progress decode spreadsheet. Nothing is 100% confirmed, use at your own risk.
Goals:
TPMS (enable/disable)
Bambi Mod (Fogs on with High Beam)
Daytime Running Lights
Seatbelt Reminder (Disable Ding)
Dome Light Mode (Theater vs. Hard on/off)
SPDR
SPDR
Nebraska
If anyone else wants to join in here is Copart vin numbers I have collected as well as standard options by model that might be helpful.
OptionXLTEddie BauerKing RanchLimited
Premium RadioOptStdStdStd
Dual Power Front SeatsN/AStdStdStd
Power Adjustable PedalsN/AN/AStdStd
Steering Wheel ControlsN/AStdStdStd
Power Folding Exterior MirrorsN/AN/AStdStd
Power LiftgateN/AOptOptOpt
Sirius Satellite RadioOptOptOptOpt
Power Running BoardsN/AOptOptOpt
XLT:​
2008 FORD EXPEDITION EL XLT 1FMFK16508LA42509
- No Power Running Boards, No Power Liftgate, No Touch Screen
2008 FORD EXPEDITION XLT 1FMFU15508LA33501
2008 FORD EXPEDITION XLT 1FMFU165X8LA49574
2008 FORD EXPEDITION EL XLT 1FMFK15538LA75084
Eddie Bauer:​
2008 FORD EXPEDITION EDDIE BAUER 1FMFU17588LA82118
- No Power Running Boards, No Power Liftgate, Unknown Touch Screen
2008 FORD EXPEDITION EDDIE BAUER 1FMFU18578LA37136
- No Power Running Boards, Power Liftgate, Touch Screen
2008 FORD EXPEDITION EL EDDIE BAUER 1FMFK18538LA62251
- No Power Running Boards, Unknown Power Liftgate, No Touch Screen
2008 FORD EXPEDITION EDDIE BAUER 1FMFK17518LA80801
- No Power Running Boards, Power Liftgate, Unknown Touch Screen
2008 FORD EXPEDITION EDDIE BAUER 1FMFK18588LA79501
King Ranch:​
2008 FORD EXPEDITION KING RANCH 1FMFU17598LA36717
- No Power Running Boards, Unknown Power Liftgate, Unknown Touch Screen
2008 FORD EXPEDITION KING RANCH 1FMFU175X8LA88177
- Power Running Boards, Power Liftgate, Touch Screen
2008 FORD EXPEDITION KING RANCH 1FMFU18518LA46673
Limited:​
2008 FORD EXPEDITION LIMITED 1FMFU20548LA12860
2008 FORD EXPEDITION LIMITED 1FMFU19538LA06092
- Power Running Boards, Power Liftgate, No Touch Screen
2008 FORD EXPEDITION LIMITED 1FMFU19588LA23664
- No Power Running Boards, Power Liftgate, No Touch Screen
2008 FORD EXPEDITION LIMITED 1FMFU20588LA27863
2008 FORD EXPEDITION EL LIMITED 1FMFK20538LA61893
- No Power Running Boards, No Power Liftgate, Touch Screen
2008 FORD EXPEDITION EL LIMITED 1FMFK205X8LA60157
2008 FORD EXPEDITION EL LIMITED 1FMFK19538LA67870
2008 FORD EXPEDITION EL LIMITED 1FMFK19568LA02091
fox_mike
Northern Plains
1FMFU18508LA41609
Premium Sound, Back Up Camera, DVD Player, Adjustable Pedals, Steering Wheel Controls, Heated and Cooled Front Seats, Front and Rear HVAC, Power Liftgate, 4WD, no Power Running Boards and no Touch Screen.
I hope the attached .pdf file helps.
  • 2FMPK4J91GBB83457 Report.PDF
G-latte
Birmingham, AL
I found out on 0720-11-01 of the first code is 9105 and changed to 9903 it provides a temp and direction on the IC as well.
G-latte
Birmingham, AL
ok so decoded 0720-11-01 as possibilities of 9103 single function line 9105 single function line 9903/9905 dual function lines (milage on top compass and temp on bottom).
07260-02-01 is TPMS management 0000 is of 0040 is on/ 2323 is 32psi 2020 is 28psi 4141 is high ply truck tires
0726-07-01 is auto lock unlock functions (must have 0720-01-01 set to xxxx 5AE4 xx) 2505 5F is auto unlock enabled 2509 60 is auto unlock disabled.
im currently working on 0726-11-01 I know its headlight control and 1400 53 is stock function but b400 is suppose to be DTRL still trying for bambi mode.
rjtehan
