2018 Expedition Rough Idle and Jerky transmission
sikikh83
Fellow i am new to this group and wanted to see if I can get some help. I bought a used 2018 expedition XLT 4x4 with 104k miles. The vehicle idles rough and the transmission is jerky as well. The first start of the day is usually the roughest, if I dont start driving the vehicle right away it misfires so bad that i start getting the blinking CEL. I hooked up to a scanner, it shows a P0305 (cylinder 5) misfire. I have changed the spark plugs, moved the coils around and even the fuel injectors but the misfires stays in cylinder 5. I even done a compression test (results attached) which looks good to me and also did a borescope of the cylinder which looks fine too. I was hoping if someone in this group can help me guide what I can do next to identify the problem? Thanks
techdude99
US
To confirm, there's a 20 PSI variance between the highest and lowest readings?
The two lowest readings are adjacent cylinders?
BMW2FORD
CT
It’s a little worrying #5 and 6 have the lowest compression and companions but before we go off the deep end - we’re both injectors for cylinder 5 moved? This engine has a manifold and injector in the head.
BP 09
Did you swap the DI injectors? Or did you only swap port injectors? Cold starts rely solely on the DI injectors only until about 120 degree coolant temps are met. Once temps reach around 120, you’ll hear the HPFP shut off and it switch to port injectors. Very obvious on these engines.
FWIW you can’t swap DI injectors without replacing seals. With over 100k and unknown service history, I’d drop about $600 on rock auto and replace all 12 injectors, 6 plugs, and 6 coil boots and call it a day!
BP 09
And as far as trans, get up underneath and check fluid level with trans temps over 200. 17 and 18 models are known to have low fluid from the factory if never serviced before.
Wouldn’t hurt to drop that trans pan and do a service. Then get set up with Forscan and reset your transmission adaptives and see how it feels.
After that, long as everything is good, get a tune and the trans will treat you nice!
SyndicateZ
Mass
Id bring the thing back to where u got it from and get a refund.
anupe
