2024 Timberline Lift
ksdirtgirl89
Kansas
I just got a 2024 Timberline and had the dealer put on a "level kit" with 18" wheels and 33 tires. Recently I noticed that the back sits lower than the front by 2". The front wheels also rub when turning. I talked to the maintenance manager at the dealership and he seems to think the only option is to either go with a 3" lift or take it back to stock. I want the extra clearance that comes with a lift because of my job but I dont want it to sit too high, mostly because Im short. Has anyone been able to do a lift and have 33 tires on it without rubbing?
Pawpaw
Raceland, La.
I have a '21 FX4 at stock height running 33 inch BFG's and no rubbing...even towing our 8K pound camper. 275x70x18 KO2's.
RacerBX1
SE Michigan
Unless you are mistaken on what you had done you were taken to the cleaners because the Timberline came from the factory leveled with a 1” lift, 18” wheels and 33” tires, and no rubbing.
ksdirtgirl89
ksdirtgirl89
Kansas
I did want the different wheels and tires already knowing the stock wheels and tires were the same size. It was just a look preference. But I dont understand why it would rub, even with the additional lift to it. I did not know that it came already leveled and I dont believe the dealership knew that either.
Pawpaw
Raceland, La.
33x11 BFG's on stock wheels. Stock height FX4 and not even come close to rubbing. Ride good on and offroad and still get great mileage and performance!
Lumberjack
Tennessee
They knew! What wheels did you go with. The wrong backspacing could be throwing you off. Look underneath, what’s there, all factory stuff or aftermarket crap? I would be going back to the stealership.
ksdirtgirl89
ksdirtgirl89
Kansas
Im going back Wednesday and we're going to get things figured out in person instead of over text. The dealership is 1.5 hours away from me so I figured we would get things done in person quicker. I also know the owner personally and he's not happy about what they did.
badfish
HTown
Can you provide an update on you r most recent dealer visit?
PalosX
