4x4 seems stuck on still after new 4x4 actuators and solenoid
terr5178
ny
I have the same truck. I'll go out tomorrow and trace the vacuum line and check that plugged port on intake. I'll send pics.
As for the selector. I had a similar problem. Broken vacuum solenoid then I used dielectric grease on the electric motor connector on the transfer case i varified it would rotate. I also removed 4wd fuse(forgot which ones) I think that reset the module and everything started working again. I have a feeling it was just corrosion on the pins and bad solenoid that confused the module and needed to be reset. Works great now.
terr5178
ny
Plu on intake plenum is correct.
My vacuum for 4wd taps into vacuum at brake booster then travels forward under engine to solenoid on fan shroud.
terr5178
ny
Looking like an electrical issue. Very common for corrosion in wires from smart junction fuse box and door saddle. I'd also try messing with any grounds under the truck ..
Staff online
waleedalmadani
