Fordgirl01
I am in the process of replacing at least my front right brake line from the hydraulic line at the wheel to the abs module. It mysteriously blew after I put new rear calipers and pads on-didn’t even get it out of the garage.[emoji2370]
So I remember doing this on one of my other vehicles (I think it was an EB expy I had at the time-I lose track since I tend to collect these big gas hogs) and I thought I remembered the fitting at the rubber hose being a standard 3/8x24 and possibly a metric weirdo at the abs module.
I decided to start switching to NiCopp brake lines, so I grabbed a piece of that with fittings at Advance Auto and a few short metric bubble flare to 3/8 x 24 adapters.
I got the old fittings out and discovered the fitting at the hydraulic hose was a bubble flare - I assumed it would be the standard inverted flare here. It looks like the original line or a factory replacement. Is this normal? It looks just like the 10mm x 1.00 that was at the abs module.
I got info from a thread on a Ford forum that the abs module needs 2-10mm x 1.00, 1-12mm x 1.00, and 1-11mm x 1.50 for the brake lines to the wheels. Mine appear to look all the same size (the 10mm x 1.00). I want to at least replace both front lines, but I want to make sure I have what I need to do the job!
Any navigator fans out there that can help a gal out?!!
