Carbon Can solenoid wire diagram Exp 2007
Chris UAE
Abu Dahbi
Expedition 2007, 5.4L V3, ECU Part number 7L1A-12A650-AGC This ECU has only two main harness connectors.
I am working on P0446, the 12V continuous live wire has continuity from the solenoid socket to the ECU connector, I cannot find the "signal " wire continuity from the solenoid socket to the ECU (solenoid unplugged). there is a harness connector above the left wheel arch, I find "signal" continuity from the solenoid socket to this connector and from here, there is a break in the wire to the ECU.
Can someone please share the ECU pin diagram for this particular model ECU, I may need to replace the "signal" wire from the ECU to the above wheel arch connector. Your valuable input will be appreciated.
