Cigarette outlet vs In dash 12v outlet
BoutTime
Conroe, TX
‘09 Expy and the cig lighter doesn’t seem to power anything plugged into it, but the 12v outlet on dash works fine.
I have tested the cig outlet other than plugging stuff into it, and I did verify there are no blown fuses.
Is there a difference (or any concern) in replacing the cig outlet with a 12v one?
The in dash 12v gets used for cell phone charging and I’m looking to power a dash cam using the cig outlet.
wpatters1229
Pleasant Hill CA
Does anyone know how to get the fuse panel that is to the left of the steering out so I can move some wiring to get the cigarette light port to be controlled by the ignition key turning on and off? The Audio fuse # 1 is switched and #3 goes to the cigarette lighter and OBDII port. I just want to move the cigarette lighter wire over to the audio fuse # 1
sharprd65
