Confused about Transmission Fluid
ski_rush
Nebraska
I have a 2007 with 200k miles. As preventative maintenance, I wanted to change the transmission fluid. When I searched online for the "right" fluid, things got confusing. Some people say only use Mercon SP. Others say that Mercon LV replaced SP, so it's fine to use. However, it even says on the Ford website that you shouldn't use LV where SP is called for (see attached pic).
Others say that Valvoline Maxlife synthetic ATF is fine to use; while others say, no way, because it's not "Ford" product and doesn't some with the correct additives.
I'm completely confused on what to use.
I don't have anything against Mercon, other than it's difficult to obtain.
71Rcode
DFW Texas
I used the LV in my 2011 expedition. Replaced what was in the pan about 2 years ago. Shifting is great as ever
Frank Wilson
PlymouthMA
Only use Mercon SP.
2007 has the 6r75 transmission
71Rcode
DFW Texas
Hey I'm questioning now what I typed just above. Looking on my garage shelf I also have mercron V. I can't remember which I used for which. Will look back at my notes. I did replace the fluid in the transfer case the differential and the transmission
Ellison Brown III
Surprise, AZ
What does the owners manual tell you to use? I’d use what the manual says when all else fails. It does recommend the SP. I’d also take into account what you’ve used that got you problem free to this particular maintenance interval. As it obviously does what it’s supposed to do.
