Cylinder misfire
cmiller1973
Louisiana
Changed coils and plugs on all 8 cylinders. Still getting misfire.
Question I have is can a clogged/malfunctioning VCT, which screws up timing, only effect 1 cylinder?
JasonH
Houston, TX
Not likely, unless there's something else happening specific to that cylinder. Check the plug wells. I think I've heard of leaking seals causing issues. Make sure the wells are dry and free of oil or coolant.
C
cmiller1973
Louisiana
None of the hoses are leaking. Everything is dry.
Reason I ask this is because of my other issues(in the other post I made) which don't make sense on a 08 with only 67k original miles. I cannot fathom the timing system going bad. I see people with 150k+ miles and just doing a timing job. That makes sense.
#3 cylinder has misfire and compression test only shows 60lbs on that one. Not leaking or burning oil either.
Really trying to figure it out before dumping more money into it only being worth $3500. Mechanic I went to wants to do a complete head job which is like 6-7k. Or drop in new crate motor for 10k+.
Yupster Dog
Super Moderator
Super Moderator
Anytime cylinder 3 or 4 is involved check heater hoses, paying special attention to the plastic T connections. Sometimes they don't leak till it heats up and then the drops get evaporated but only after throwing a code.
Many threads in here telling that tale.
Arkansas
I went through the spark plug and coil replacement and still had a misfire, replaced the phasers chains and blocked the VTC, sent the computer and deleted the VTC feature, replaced the oil pump with a HV pump and replaced the solenoids.
Still had a misfire...
Then...
I cleaned the injectors...
https://youtu.be/-eDcY0WhALI?si=Zplcybs_ypD-S8Af
placed a hose over the top or inlet of the injector and taped the straw from the carb cleaner to the other end of the hose, connect 9V battery to injector and open the injector plunger and sprayed for 5 sec twice.
I also replaced the valve springs and seals.
No more misfire
C
cmiller1973
Louisiana
No more misfire
I think with low cylinder pressure, a bigger issue is likely valves. Mechanic said it had 60lbs max.
