EOTM Theme for June: Most MODS!!!
Hampton, VA
Hello everyone.
I apologize for being late with this, I havent been able to get on like i'd like. June is another month and have dubbed it "MOST MODS". So get your list out of what youve done to your truck and LIST AWAY!!!
Please number your mods one of two ways. 1)...2)...3)...or 23 mods total mods followed by what the mods are. As always, except for last month, submissions will end 3 days prior to end of month. June 27 is the last day, eastern, to submit photos and voting will begin the 28th...ending the 30th. Winner will be announced on 1 July. GOOD LUCK!!!
If you have any questions, concerns, or comments please let me know by PM or email at [email protected]
//SINGED//
FREEWAY
CR_Magruder
Oregon
CR_Magruder: June ETOM Submission
Re-power mods should count... or so I'm thinking; maybe the moderators think differently, so I will defer to them.
My Expy is stock "except" for being re-powered. Stock wheels, suspension, paint, sound system, etc..
Here is the list of mods done so far to make the transplant:
1.Cut off stock motor mount cradles from the frame; re-weld shortened, gusseted versions back on.
2.Eliminated the in-tank fuel pump, replace fuel lines with Teflon.
3.Removed fuel filler neck and drilled out the “unleaded fuel” flapper/ diameter reducer with a hole saw and die grinder, then re-installed. Add “diesel fuel only” labels to inside filler door. Performing these mods caused me to grin nearly the whole time.
4.Removed the 4R70W transmission, replaced with a manual M5R2.
5.Modify transmission support member to hold up new manual trans.
6.Removed the transmission oil cooler and coolant tubes.
7.Re-wire transmission connector fitting on the PCM to communicate a neutral condition to PCM all the time.
8.Cut hole in floorboard for manual shift lever; fabricate boot; cut hole in console plastic side panel for the new shift lever.
9.Fabricated custom shift lever.
10.Shorten the back driveline and lengthen the front driveline, since the stock transfer case connected to the new transmission was a little further back than when original auto trans.
11.Remove stock brake pedal; replace with 2003 F-150 clutch & brake pedal.
12.Add hydraulic clutch slave cylinder and hydraulic line.
13.Re-wire “start in park or neutral” safety circuit to become “start with clutch pushed to floor” circuit.
14.Re-locate alternator to custom fabricated mount on 4BT Cummins engine.
15.Remove the stock wimpy battery cables and replace with 4-0 starter and engine ground cables.
16.Added battery heater, engine oil pan heater and coolant heater to engine.
17.Add air-to-air intercooler and related plumbing. Required modding the plastic cowling between the grille and radiator support panel.
18.Relocate power steering cooler (to make room for the intercooler).
19.Fabricate new coolant hose jumpers, tube and adapter fittings to/from engine and stock radiator.
20.Added electric fans to the radiator; thermal switch on the engine controls the fan relays.
21.Modify engine wiring harness by eliminating most every sensor needed for the 5.4L engine.
22.Re-locate crankshaft position sensor to new mount on the pulse dampener/crank pulley of the 4BT engine.
23.Re-locate the coolant temperature and oil pressure sensors to new fittings on the 4BT engine.
24.Remove stock air filter. Replace with bigger AEM filter and 4” aluminum intake tubing to turbo.
25.Fabricated new power steering tubes, fittings and hoses connecting stock steering gear to Dodge power steering pump on the 4BT engine.
26.Discarded the 5.4L “vacuum pump” and re-connected vacuum brake boost diaphragm to Dodge vacuum pump on the 4BT engine.
27.Remove catalytic converters, O2 sensors and all stock exhaust. Replace with custom 3” straight pipe, more or less following stock routing on the passenger side. This also includes fabricating a custom “cobra head” stainless steel sheetmetal fitting for the back of the turbo.
28.Relocate the A/C compressor to a new mount on the 4BT engine. This required reworking the inlet & outlet tubes that connect to the manifold.
29.Oh yeah, one more—liberated the stock 5.4L engine and replaced with a Cummins 3.9L 4BT engine. I did not include the following modifications in the list, since these were done to the engine, not the Expedition (but maybe they could be used for a tie-breaker?):
a. Modified the oil pan to not hit the front axle ring & pinion housing.
b. Fabricate new motor mounts to mate stock liquid-filled isolators to the modified frame mounts.
c. Added a Dodge combination vacuum pump and power steering pump.
d. Modified the crankshaft pulley / pulse dampener by machining the OD with notches for the crankshaft position sensor.
This concludes my entry for the June EOTM.
CR
tallsville
LA
tallsville: June EOTM Submission
just to see if i can remember my mods and see how many i have done.
1. spintech catback exhaust
2. k&n FIPK/CAI
3. Sound System
a. 1000w amp
b. 2 bravox 12" uxp's
c. pioneer HU
d. 0 gauge wire
e. gain/bass knob installed in dash
4. HID 8k headlights
5. euro designz foglights
6. 285/70/17 tires
7. limo tint on rear 5, dark tint on front 2
8. custom bent running boards courtesy of rocks while offroading
9. pink ribbon car badge
10. "if you cant stop smile as you go under" license plate frame
11. removed mods
a. 2005 f150 rims
b. blue interior lights(cuz of ex)
12.mods by previous owner
a. sunroof
all i can remember for now
oblivion
Ontario Canada
oblivion: June EOTM Submission
1) Gibson 3” Cat back
2) Gots Mod
3) K&N air filter
4) New Aftermarket manifolds
5) Accel COP
6) Fixed cold soider on dash cluster
7) 20% tint
8) 3” Cannuck Motorsports drop kit
9) Dostech Nitro Slammer Shocks
10) 20” AR black burn Rims
11) 275/45/20 goodyears
12) Front and rear fenders rolled
13) EBC green stuff brake pads front and rear
14) Brembro Blanks front brake rotor
15) Black housing projector headlights
16) Black housing turn signals
17) Tinted tail lights
18) Rewired 3rd projector to highbeam
19) 6000k Low beams
20) 6000k Fog lights
21) PTM front valance
22) Double DIN source unit conversion
23) Rear view camera in place of tailgate lock tumbler
24) 200+ sq/f Sound deadening
25) Upgraded and added additional Grounds to engine
26) 7” headrest monitors
27) Video distribution amplifier
28) Removed stock changer from center console
29) 3 kinetik batteries
30) 80’ feet 0ga power and ground wire
31) Removed stock subwoofer and amp
32) Rewired all 4 speakers with 12 ga wire
33) All 4 speakers replaced with high end replacements
34) Custom Subwoofer enclosure/amprack
35) Blacked out antenna
36) 1-4ch 850w amp
37) 1-mono 1550W amp
38) Installed baby seat LMAO
Theres more just cant think of it now.
And a fun pic to go along
