F150 Wheels
MattG
Toronto
Yes, beating a dead horse with the same topic but spare me the flack!
'20 Expy CCD 22s
'18 F150 20" Sport wheels
What/where can I get the front and rear spacers? I read 5mm front and 10 mm back, this is correct?
Looking for no modifications to axle shafts or any other part of the Expy, just want to swap my OEM 22s for the 20s winter tires come December, this is the route to go, yes?
Thank you
scottdm
Western PA
M
MattG
Toronto
Thanks for the reply. I'm in Canada so what little options remain for take offs or reproduction are limited. Prefer not to ship through US if not.
Can get a set of F150 takeoffs for reasonable price.
Wasn't sure if just keeping the rear center caps off was fine. Will go that route with the 275/55/20 winter rubber.
Appreciate the response.
scottdm
Western PA
Sure, no problem. Some guys spray the protruding part of the axle shaft with rattle can bed liner or similar to clean it up a bit. The ends of the axle shafts get really rusty hiding behind the center caps.
Ellison Brown III
Surprise, AZ
It took me about 30-45min to cut the excess axle protruding through the center of the wheel. Still have 3 to 4 threads of the spindle through the nut. In the aviation field we look for at least 2 to 3 threads. If it’s good enough for a helicopter it’s good enough for my Expy. It’s been approximately 3 years since I’ve done the mod, and if you don’t know what your looking for you can’t tell the difference.
