john shelman
My 2003 expedition didn't come with factory installed fog lights. But while working under it, I noticed that the harness and plugs for those lights were there on each side, and I found that the assemblies for the lights are easy to find. I know that the headlight switch will also have to be replaced, also easy. But when I pulled that switch from the dash, I could not seem to find the plug that would go into a new switch. I know wiring harnesses usually have plugs for all the optional things, whether they are installed or not. So, if the wiring is there down where the lights would be, shouldn't the wires that would feed them, the ones at the switch end, be there too? I would really like to add these lights.
