I believe you will need the harness. The expeditions without fog lights don’t have the connectors or wiring for the fogs built into the light harness, from the factory.Hello, I have an 2022 XLT and I bought the actual fog lights from FORD, after having them at hand I realized that I also needed the "FOG LAMP END COVER", also the "FOG LAMP BEZEL TRIM MOLDING" and some screws, also I needed a different "Headlight Switch" assembly since the one equipped doesn´t control fog lights. I have the fog lights at hand, and every other part is in the cart, but now I wonder if I will need a "fog light wire harness", and also, have the same concerns you have, how hard will it be to do this my self!
