FORSCAN on Linux
cmc3
Florida
Forscan appears to be working under linux-wine now. I haven't checked all the functions, but everything I've looked at appears to work just as it did under windows.
FORSCAN version: 2.3.50
Fedora 37, XFCE, x86
Wine version 8
Adapter OBDLinkEX
The windows device driver is NOT required.
Use root to add yourself to the "dialout" group.
Tested on my 2017 Expedition XLT
LokiWolf
Super Moderator
Super Moderator
Richmond VA
@Yupster Dog Can you move this to FORSCAN.
So, as a geek I appreciate it. I do not recommend this unless it is fully supported by FORSCAN. Just cause it works on the surface, doesn't mean it should be used. This is the same as using it in a VM on Mac. You are adding a conversion layer. Not supported, and adds another level where there could be a problem. Obviously you know what you are doing and dealing with, and are comfortable with Linux.
Run a special flavor of Fedora?
cmc3
cmc3
Florida
I've used Linux for everything for a long time. I have one remaining Windows 11 laptop which I seldom use.
You are correct about WINE being a extra (probably slightly buggy) layer. It has been under development for a long time. But doesn't work for everything. To date I have found no FORSCAN functions that do not work under WINE just like the did under windows.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Cool!
While, yeah, like I said above, probably will work. When it doesn't, will it be a critical point?
oelkersbrian
